msmsitech
Apr 04, 2019Aspirant
ReadyNAS 424 front display showing "(null)+0"
We have a new (just past 90 days) Readynas 424. The front display shows (null)+0. It seems to be running alot but the system status or log shows no issues. Any ideas? We have no Apps installed. 6.9.4 hotfix1 installed.
Thanks for your help.
Did you try rebooting it?
Also, I'd suggest updating the firmware to 6.9.5 or perhaps 6.10.0.
- msmsitechAspirant
I am running a backup at the moment. When it is done I plan on rebooting. I was just looking for a cause. I have found no paperwork or web pages that this these error messages. Thanks for the reply. I will reboot it shortly.
- msmsitechAspirant
Ok, Rebooted and updated software to 6.9.5 which is the latest version . Still if anyone has an Idea of what the issue is then i would love to know. I like to be proactive.
