gn00347026
Dec 27, 2017Guide
"(null)+0" on RN516 front display
Hi all
I have a rn516, it cannot boot up after normal restart. It shown null +0 and the panel
Thanks
Thanks
It could be caused by an add-on crashing for example, but that error is very generic so there are a range of possibilities.
You likely need support via my.netgear.com.
If you purchased your NAS (new) between 1 June 2014 and 31 May 2016, then you have lifetime free chat support.
Thanks stephen first
but anyone encountered the same issue, can any one give me some hints first?
You could try forcibly powering down the NAS, and then restart it. Likely that will work, but the problem might recur.
