gn00347026
Dec 27, 2017Guide
"(null)+0" on RN516 front display
Hi all I have a rn516, it cannot boot up after normal restart. It shown null +0 and the panel Thanks
- Dec 27, 2017
It could be caused by an add-on crashing for example, but that error is very generic so there are a range of possibilities.
Dec 27, 2017Guru - Experienced User
You likely need support via my.netgear.com.
If you purchased your NAS (new) between 1 June 2014 and 31 May 2016, then you have lifetime free chat support.
gn00347026
Dec 27, 2017Guide
Thanks stephen first
but anyone encountered the same issue, can any one give me some hints first?
- StephenBDec 27, 2017Guru - Experienced User
You could try forcibly powering down the NAS, and then restart it. Likely that will work, but the problem might recur.
- mdgm-ntgrDec 27, 2017NETGEAR Employee Retired
- gn00347026Dec 28, 2017Guide
Thanks and Mdgm and Stephen
the addon -syslog fill up the root partition, after deleted the /var/log files and reboot , it resumed to normal!
Thanks for your help and wish you 2 a very happy new year!
