gn00347026
Dec 27, 2017Guide
"(null)+0" on RN516 front display
Hi all I have a rn516, it cannot boot up after normal restart. It shown null +0 and the panel Thanks
- Dec 27, 2017
It could be caused by an add-on crashing for example, but that error is very generic so there are a range of possibilities.
Dec 27, 2017Guru - Experienced User
You could try forcibly powering down the NAS, and then restart it. Likely that will work, but the problem might recur.
mdgm-ntgr
Dec 27, 2017NETGEAR Employee Retired
- gn00347026Dec 28, 2017Guide
Thanks and Mdgm and Stephen
the addon -syslog fill up the root partition, after deleted the /var/log files and reboot , it resumed to normal!
Thanks for your help and wish you 2 a very happy new year!
- mdgm-ntgrDec 28, 2017NETGEAR Employee Retired
If you don't remove the add-on that created the large log file then the problem will likely come back.
uninstalled ^^V
