msmsitech
Apr 04, 2019Aspirant
ReadyNAS 424 front display showing "(null)+0"
We have a new (just past 90 days) Readynas 424. The front display shows (null)+0. It seems to be running alot but the system status or log shows no issues. Any ideas? We have no Apps installed. ...
msmsitech
I am running a backup at the moment. When it is done I plan on rebooting. I was just looking for a cause. I have found no paperwork or web pages that this these error messages. Thanks for the reply. I will reboot it shortly.
msmsitech
Ok, Rebooted and updated software to 6.9.5 which is the latest version . Still if anyone has an Idea of what the issue is then i would love to know. I like to be proactive.
- StephenBApr 04, 2019Guru - Experienced User
It showed that because something crashed. It might not recur (though of course, it might).
I suggest downloading the log zip file via the admin web ui. You can then ask one of the mods to analyze it for you ( JohnCM_S or Marc_V ). Don't post a link to the logs here, there is information in them that shouldnt be public.
