dsnpevl
Jun 09, 2016Virtuoso
"(null)+1" on RN516 front display
My RN516 shows "(null)+1" on the front display and Admin pages are not reachable. Recently I swapped a disk and I think backup to USB or remote RN312 are running. How can I regain control over t...
- Jun 11, 2016
dsnpevl wrote:When I try to access the admin page, I always end up at the message "ReadyNAS Admin Page is offline". I now physically disconnected the USB drive to see if that will stop the backup processes and bring back control.
Pulling the USB drive cable didn't change the symptoms. Still couldn't access the Admin Pages. Also ended up having to rebuild the USB drive (write zeros and reformat).
Forcilbly shutting down and restarting the RN516 solved the issue. Access the adming pages is re-esthablished and backup to rebuild USB drive works.
Still don't know what caused the (null)+1 message on the front display. Is there any way to find out what caused this, so I can try to prevent it from happening in the future?
JennC
Jun 09, 2016NETGEAR Employee Retired
Hello dsnpevl,
What is the current FW version? Do you have full backup of the data? Can RAIDar still detect it?
