CharlesElliott
Sep 30, 2012Aspirant
NV+ 4.1.10 upgrade failed
I have just had a similar problem to others on here after upgrading their NV+ to 4.1.10 - unit says 'Booting....' and then just hangs indefinitely with no sign of activity and cannot be seen RAIDar. ...
PapaBear1
Oct 07, 2012Apprentice
jbartec - I would recommend you update your backup or create one if you don't have one. Running with only three of the four disks of an array is not recommended. Once you have a full backup you could try a factory default.
