CharlesElliott
Sep 30, 2012Aspirant
NV+ 4.1.10 upgrade failed
I have just had a similar problem to others on here after upgrading their NV+ to 4.1.10 - unit says 'Booting....' and then just hangs indefinitely with no sign of activity and cannot be seen RAIDar. ...
mdgm-ntgr
Oct 08, 2012NETGEAR Employee Retired
christopher normally remotely upgrading the firmware would be fine. I haven't had any issues doing that myself.
As for the Remote issues once you get the NAS back up and running I guess that could be looked into. By comparing the configuration etc. with a working system the problem should hopefully be easy to identify.
