CharlesElliott
Sep 30, 2012Aspirant
NV+ 4.1.10 upgrade failed
I have just had a similar problem to others on here after upgrading their NV+ to 4.1.10 - unit says 'Booting....' and then just hangs indefinitely with no sign of activity and cannot be seen RAIDar. ...
avpman1
Oct 21, 2012Aspirant
I'm having exactly the same problem. NV+ will only boot if one of the four drives is removed. Downgrading firmware to 4.1.8 fixes it (4.1.9 also has the bug.) NV+ has the 1gb upgrade.
jbartc: the problem is not specific to your fourth drive, remove any drive and it will reboot w/o a problem. Try to revert your firmware to 4.1.8 then reboot your NV+ with the 4th drive installed. It should boot and re-sync. The link to 4.1.8 is: http://www.readynas.com/download/RAIDiator/RAIDiator-4.1.8
good luck
p.s. if you have auto update enabled you might want to disable it before downgrading.
good luck
