CharlesElliott
Sep 30, 2012Aspirant
NV+ 4.1.10 upgrade failed
I have just had a similar problem to others on here after upgrading their NV+ to 4.1.10 - unit says 'Booting....' and then just hangs indefinitely with no sign of activity and cannot be seen RAIDar. ...
ReadyNASUser
Oct 30, 2012Aspirant
christopher wrote: <snip> The 1 gig SODIMM I installed has worked fine for the past 5 years. It's Kingston p/n KVR333SO/1GR </snip>
Any comment on all this from NetGear... NV+ purchased 2008, same 1Gb of Kingston memory as "christopher" installed at time of purchase; I'm on 4.1.9 with no problems... should I "risk" the upgrade or is 4.1.11 in the works to remove what appears to be a consistent issue with 4.1.10 and 1Gb NV+ configurations...
