CharlesElliott
Sep 30, 2012Aspirant
NV+ 4.1.10 upgrade failed
I have just had a similar problem to others on here after upgrading their NV+ to 4.1.10 - unit says 'Booting....' and then just hangs indefinitely with no sign of activity and cannot be seen RAIDar. ...
Probie
Jan 14, 2013Aspirant
I have the same problem - 4.1.10 hangs during boot (Nv+ v1 with 1GB RAM).
I have to remove disk 4 in order to get it to boot.
There are some kind of bug in 4.1.10. (I've had 1GB for ages and it has worked perfect until 4.1.10 was installed)
I'm currently reverting to 4.1.9 and hope that will help. If not, I'll try 4.1.8.
