CharlesElliott
Sep 30, 2012Aspirant
NV+ 4.1.10 upgrade failed
I have just had a similar problem to others on here after upgrading their NV+ to 4.1.10 - unit says 'Booting....' and then just hangs indefinitely with no sign of activity and cannot be seen RAIDar. ...
jhp960011
Feb 15, 2013Aspirant
4.1.10 firmware is broken.
After two months of back and forth with Netgear tech support, My NAS is finally back up and running. I spent a whole lot of time with support, who had me spend several $100s buying new RAM and hard drives only to find 4.1.10 does not work with NVs and 4 hard drives. On a whim, I went back to a previous firmware and it worked! I came to the forums, and low and behold the folks in this thread found the same problem. Will Netgear fix this?
