CharlesElliott
Sep 30, 2012Aspirant
NV+ 4.1.10 upgrade failed
I have just had a similar problem to others on here after upgrading their NV+ to 4.1.10 - unit says 'Booting....' and then just hangs indefinitely with no sign of activity and cannot be seen RAIDar. ...
Mar 10, 2013Guru - Experienced User
If you aren't running the stock RAM you might need to downgrade (4.1.8 or 4.1.9).
