CharlesElliott
Sep 30, 2012Aspirant
NV+ 4.1.10 upgrade failed
I have just had a similar problem to others on here after upgrading their NV+ to 4.1.10 - unit says 'Booting....' and then just hangs indefinitely with no sign of activity and cannot be seen RAIDar. ...
ChrisMc73
Mar 16, 2013Aspirant
StephenB wrote: If you aren't running the stock RAM you might need to downgrade (4.1.8 or 4.1.9).
What are the steps to downgrading to 4.1.8 from 4.1.10? I'm assuming you can do this without losing your data, just a firmware downgrade right?
Also, those that are just pulling a drive and it comes up, do you reseat your drive and it resyncs and everything is normal again?
