djkball
Dec 06, 2012Aspirant
NV+ disk#4 uninitalized
After looking at the logs i noticed that disk #4 became uninitalized . When i boot it up into Arconis it shows the disk uninitialized. Is there an easy way to save the disk and re-initalize it so i c...
mdgm-ntgr
Dec 06, 2012NETGEAR Employee Retired
Which log? Can you post an excerpt from that log? Disk 4 is typically the parity disk (assuming you last did a factory default with all four disks in place and are using X-RAID)
