djkball
Dec 06, 2012Aspirant
NV+ disk#4 uninitalized
After looking at the logs i noticed that disk #4 became uninitalized . When i boot it up into Arconis it shows the disk uninitialized. Is there an easy way to save the disk and re-initalize it so i c...
djkball
The device lost power on Sunday and now have some major disk issues. I know that disk #0 or slot #1 is bad. Also i thought that disk #1 or slot#2 was bad so i created an image of it with acronis incase i had to recover it. I tried putting a know good drive back in slot #1 and it wouldnt rebuild so i started looking at the logs and found that disk #3 slot #4 is showing faulty in the logs ( shown below). So i took that drive out and was going to make an image of it also so i could recover it to another disk but disk shows uninitialized. So i assume it lost its MBR or partition information. I figured if i could get this disk repaired and it boots it would put the raid back online and then i could recover my data .
PHYSICAL_DRIVE: 3: DISK<N:3/4,hdi(56,0),ID:3,PT:1,SZ:2930256688,ST:P :faulty>
