djkball
Dec 06, 2012Aspirant
NV+ disk#4 uninitalized
After looking at the logs i noticed that disk #4 became uninitalized . When i boot it up into Arconis it shows the disk uninitialized. Is there an easy way to save the disk and re-initalize it so i c...
mdgm-ntgr
Dec 06, 2012NETGEAR Employee Retired
As I said disk 4 is typically the parity disk. It is normal for it to appear uninitialised. However from what you posted it looks like there is an issue with that disk. Have you tried testing it using vendor tools (e.g. SeaTools if it is a SeaGate disk)?
So you don't have an up to date backup?
I'd suggest opening a tech support case and working with NetGear support on this issue. You can send the logs zip file to them when they request it (or if it is an online case, attach the logs zip file to the case). If over 90 days since purchase make an online submission to NetGear.
