bdsh
Mar 14, 2013Aspirant
NV+ Frozen on "Booting..."
Hi, I have a NV+ with 4 x 2TB drives and the stock standard 256meg RAM, running firmware v4.1.9. This NAS has operated reliably for 4.5 years (bought new and still under warranty) and is rarely turne...
Mar 19, 2013Guru - Experienced User
My WDC WD20EARS drives are around 24000 hours (2.7 years) and still seem to be working ok. That's when I first fired up the NV+. I never ran wdidle.
Yours should still be under warranty (see http://www.theverge.com/2011/12/17/2641 ... ction-2012). There's a tool you use here to check: https://westerndigital.secure.force.com ... ck?lang=en
Though I'd suggest using any refurbished replacement you get somewhere else.
I've been using WDC 3 TB red drives with some success in my Pro (also in the new RN102). I haven't used the 2 TB models in an NV+, though the 3 TB models are working out very well for me.
