idahoharleydude
Jul 04, 2011Aspirant
NV NIC P/N RNV1-S2-0000
I think the network interface in my NV+ is dying. Is it replaceable?
PapaBear1
Jul 04, 2011Apprentice
No.
If you still have access to the data, back it up now, the critical data first.
Depending on how old the NV+ is, it may still be under warranty. You can open an on line case with technical support and then edit the header of your first post to add the case number.
