idahoharleydude
Jul 04, 2011Aspirant
NV NIC P/N RNV1-S2-0000
I think the network interface in my NV+ is dying. Is it replaceable?
mdgm-ntgr
Jul 05, 2011NETGEAR Employee Retired
Any Sparc ReadyNAS (ReadyNAS that runs RAIDiator 4.1.x) in a working condition with 4 or more drive bays will work. Migration would work fine provided all your disks are fine (you have a redundant array). I would ensure the NAS you migrate to is running 4.1.7 then power down, both NASes and migrate as follows: http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
Of course after powering down the X6 you should remove all disks from it and label the order of the disks.
It might be time to get your first x86 ReadyNAS and transfer the data across your network from the X6 to e.g. an Ultra or Pro.
