idahoharleydude
Jul 04, 2011Aspirant
NV NIC P/N RNV1-S2-0000
I think the network interface in my NV+ is dying. Is it replaceable?
- idahoharleydudeAspirantI did not get an X6...
Has hoping to get the data of with a USB drive attached rather than buying an unpopulated NAS to transfer the drives to. The drives are maxed out and I was ready to upgrade anyways. I want to go to an x86 ReadyNAS eventually. If I have to buy an older NV now, its gonna be even longer before I can get a new model.
I have the Still haven't turned NV+ on since the NIC started flaking out. I'm pretty sure it will stay connected long enough for me to configure the job. - PapaBear1ApprenticeI appologize, I was confusing this thread with another, and thought you had an old X6 (predecessor to the NV and then NV+).
Reading the manual, if you connect a large enough USB drive to the front port and then hit the backup button, it will back up the data in the backup share. You can then also configure backup to backup the other shares, but of course you have to have the NIC working to do this.
Of course the ideal situation would be if you can borrow a friend's NV/NV+ for a period of time to do the backup.
