Beyondhelp00
Sep 10, 2018Aspirant
NV+ Problem video link included of lights
Customer of mine has this NAS and has been working fine for some time. Hes just come back from holiday, and its now offline.
Any idea whats going on? The closest I can get from the LED document...
- Sep 17, 2018
Ok found that, just needed file sharing enabled on extra features on windows 10. I'll close this thread now. Thanks for the help everyone.
Marc_V
Sep 10, 2018NETGEAR Employee Retired
Hi Beyondhelp00
Welcome to the Community!
Have you tried checking the NAS Status using RAIDar? Please see Downloads for previous ReadyNAS devices.
There might be failing drives or full OS partition. Was there any recent updates made? You can try to reboot and see if it will proceed normally.
Worst is that it might need a Factory reset, does your client have a backup of their Data?
You may want to make sure that it is a V1 or V2 NV+ you can visit this link to verify.
Regards
- Beyondhelp00Sep 16, 2018Aspirant
I've now picked up the unit from my customer. I'm going to look into it. Its been a long time since it was installed, am I safe to pull a drive out one at a time (there are three) and see if it then behaves ok?
Just to add this is a three drive array, using X-Raid. There is no other backup.
Updated with the model number.
