bartsimpson
Jul 25, 2011Aspirant
NV+ (RND4000) —» RAID 1 over > 2 HDDs possible?
Greetings, For the ReadyNAS NV+ (RND4000), is it possible to operate RAID 1 over more than 2 HDDs? If so, how may an additional HDD be designated as the third or fourth mirror of the RAID without r...
mdgm-ntgr
Jul 25, 2011NETGEAR Employee Retired
RAID-1 is a 2-drive array. RAID-1 doesn't make sense with any other number of disks. There are different kinds of RAID used when you have more disks. On a Sparc ReadyNAS (e.g. NV+) you could use RAID-5 (still protects against a single disk failure) or RAID-5. I believe you can add an additional drive as a hot-spare which would automatically be used to rebuild the array after a disk fails.
On Sparc ReadyNAS (e.g. NV+) only X-RAID arrays can have additional drives added into an existing array. See X-RAID in Action. You cannot add a disk as a hot-spare to an X-RAID array, only to Flex-RAID (e.g. RAID-1, RAID-5).
