937carrera
Mar 01, 2014Aspirant
NV+ slows after 15-20 minutes [SOLVED]
I am experiencing some performance issues with my NV+ It is used for storing drive images created using the Acronis Drive Image 2010 CD. Backups work fine, the issue arises when I come to do a rest...
Mar 01, 2014Guru - Experienced User
I think I would try upgrading the firmware. You can always downgrade again if there is a problem. I'd also check the OS fullness (requires ssh) or alternatively delete all logs from frontview (system and backup).
Maybe also check the SMART stats for the disks.
The NAS shouldn't be sending jumbo frames if the setting is off and the MTU set to 1500. So that is strange.
