937carrera
Mar 01, 2014Aspirant
NV+ slows after 15-20 minutes [SOLVED]
I am experiencing some performance issues with my NV+ It is used for storing drive images created using the Acronis Drive Image 2010 CD. Backups work fine, the issue arises when I come to do a rest...
vandermerwe
Mar 01, 2014Master
Have you considered updating the firmware?
Don't think this will solve your problem, but probably advisable.
You could also test all the disks using vendor tools, if doing this only remove and reinsert with Nas off.
EDIT: didn't see last post from StephenB, my post doesn't add anything.
