937carrera
Mar 01, 2014Aspirant
NV+ slows after 15-20 minutes [SOLVED]
I am experiencing some performance issues with my NV+ It is used for storing drive images created using the Acronis Drive Image 2010 CD. Backups work fine, the issue arises when I come to do a rest...
Mar 02, 2014Guru - Experienced User
I don't believe there is any issue with the tib file - the "poor media quality" warning is probably something to do with a response to a read that Acronis thinks is too slow.
What makes this odd is that the NV+ is 2x the speed of the old Synology. Did you look at the network stats saved on the NV+?
Of course if the NV+ is sending JF despite the MTU setting, that could result in fragmented packets reaching the PC. That might create some lost packets/retransmissions which could maybe explain the error???
