937carrera
Mar 01, 2014Aspirant
NV+ slows after 15-20 minutes [SOLVED]
I am experiencing some performance issues with my NV+ It is used for storing drive images created using the Acronis Drive Image 2010 CD. Backups work fine, the issue arises when I come to do a rest...
Mar 02, 2014Guru - Experienced User
On the NV+ vs Synology speeds, I was going simply by your read speeds (which is what is relevant to the Acronis restore). You got ~15 MB/s for the Synology, and ~30 MB/s for the NV+. Both had about the same write speeds.
The NV+ was certainly very competitive in its day - the ARM-based systems of course provide much better performance at that price point today.
The stats are on Network->interfaces (show errors button). That might be the same as the "lost packet" information you were talking about.
If you were using wired ethernet, of course there shouldn't be any lost packets.
