937carrera
Mar 01, 2014Aspirant
NV+ slows after 15-20 minutes [SOLVED]
I am experiencing some performance issues with my NV+ It is used for storing drive images created using the Acronis Drive Image 2010 CD. Backups work fine, the issue arises when I come to do a rest...
937carrera
Mar 03, 2014Aspirant
Thanks again. yes, the lost packet information was from the network> interfaces tab, and it is wired ethernet so there are packets being lost where there should not be. That's also part of the reason why I reset the couters a couple of times, just to verify how mant new packets were being lost. This is typical of what I would see
Auto-negotiation 0
Bad packets 0
Disconnect 0
False carrier 0
Idle errors 0
Link failures 0
Receive errors 0
Symbol errors 0
VLAN tags 0
TCP Retransmits 1094
Unrecovered TCP Retransmits 230
Auto-negotiation 0
Bad packets 0
Disconnect 0
False carrier 0
Idle errors 0
Link failures 0
Receive errors 0
Symbol errors 0
VLAN tags 0
