937carrera
Mar 01, 2014Aspirant
NV+ slows after 15-20 minutes [SOLVED]
I am experiencing some performance issues with my NV+ It is used for storing drive images created using the Acronis Drive Image 2010 CD. Backups work fine, the issue arises when I come to do a rest...
937carrera
Mar 03, 2014Aspirant
I'll give that a go, I think the challenge will be to see if I can allocate a fixed IP while in the rescue CD environment.
I'll create another image and then try and restore it (both with direct connection) and see how long it takes. I'll be back in a few hours :)
