937carrera
Mar 01, 2014Aspirant
NV+ slows after 15-20 minutes [SOLVED]
I am experiencing some performance issues with my NV+ It is used for storing drive images created using the Acronis Drive Image 2010 CD. Backups work fine, the issue arises when I come to do a rest...
937carrera
Mar 04, 2014Aspirant
StephenB wrote: False carrier and idle errors are definitely not good. It makes me wonder about the cabling between the PC and the NAS, as well as the PC nic (since we didn't see these errors when the NAS was connected to the router).
I deliberately used the same cable between the pc and the nas as between the switch and the NAS to ensure that would not be a variable. I also used a netgear supplied cable to ensure some sort of quality control. In my testing before writing the post I used various nic cables. changing them didn't seem to make any difference.
11 hours later and the 99% of memory is still allocated. When I used NASTester you could clearly see the memory usage jump up as tasks were carried out, and then drop away to the normal 12-15% when they were complete. that didn't happen with the Acronis backup where the memory remained allocated. As I properly cancelled the job through Acronis (which helpfully said "job successful" after aborting !) it looks like the nv+ hasn't reacted / received the message or it has simply stalled in that job. Frontview etc are slow to respond and fan speed was up at 1923 rpm, even though nothing active has been going on overnight. Hard disk temperatures were 40 C for the middle two and 35 C for the outer ones, so nice & cool.
i'm happy to continue to do some more testing, what's the best course of action from here ?
ps, can you explain what the false carrier / idle errors are..... could it be because i hot swapped the network cable to reset the counters and then hot swapped back ?
