937carrera
Mar 01, 2014Aspirant
NV+ slows after 15-20 minutes [SOLVED]
I am experiencing some performance issues with my NV+ It is used for storing drive images created using the Acronis Drive Image 2010 CD. Backups work fine, the issue arises when I come to do a rest...
937carrera
Mar 04, 2014Aspirant
Hmm, this isn't an easy problem to solve is it.
I have just received a used Readynas Duo, which I intend to use for further testing. This means I should be able to replicate the same test using alternate firmware versions to see if that resolves the problem or not.......... without putting my core data at risk. I have a small 80GB disk which I am just doing a factory reset on, I'll post a progress report later.
In the meantime I am grateful for all the help so far and for any further assistance or suggestions
