937carrera
Mar 01, 2014Aspirant
NV+ slows after 15-20 minutes [SOLVED]
I am experiencing some performance issues with my NV+ It is used for storing drive images created using the Acronis Drive Image 2010 CD. Backups work fine, the issue arises when I come to do a rest...
Mar 04, 2014Guru - Experienced User
I have accessed shared from Windows XP, and I've always used user mode security.
Anyway, did you reset the owner/group and permissions using the advanced tab of the shares?
