937carrera
Mar 01, 2014Aspirant
NV+ slows after 15-20 minutes [SOLVED]
I am experiencing some performance issues with my NV+ It is used for storing drive images created using the Acronis Drive Image 2010 CD. Backups work fine, the issue arises when I come to do a rest...
937carrera
Mar 06, 2014Aspirant
I have run some tests on the new Duo. It is noticeably quicker than my NV+ and I successfully restored a 21MB archive in about 30 minutes on firmware 4.1.6
I have moved onto 4.1.7 and am running that restore again, all seems to be progressing well. My plan was to move the Duo onto 4.1.13 and then repeqat the upgrade path on the NV+
Having drunk too much coffee I decided to just work my way through all the logs and see if there was anything that couold be of interest. I have posted my partition.log below; it looks to me as though one of my 2TB hard disks has lost its partition table. I presume that will wreak havoc with internal processes as the NV+ tried to pull data from a disk with no partition, then it has to go to another part of the raid array to get the data.
Does this make sense, and what's the best way to recreate the partition structure on the problem disk. Do I simply hot remove and replace and let it rebuild the RAID array, or is there a better method / command that reduces the risk of data loss (I have 3.0TB used from 5.4TB available from 4 x 2TB drives.
I assume hde corresponds to disk 2, second from the left ?
and an extract from system.log
Disk /dev/hde doesn't contain a valid partition table
Disk /dev/hdc: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608032 3907008687 1951200328 5 Extended
/dev/hdc5 4608040 156280863 75836412 8e Linux LVM
/dev/hdc6 156280872 3906992311 1875355720 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
Disk /dev/hdg: 2000.3 GB, 2000388448256 bytes
/dev/hdg1 32 4096031 2048000 83 Linux
/dev/hdg2 4096032 4608031 256000 82 Linux swap / Solaris
/dev/hdg3 4608032 3907008687 1951200328 5 Extended
/dev/hdg5 4608040 3906992303 1951192132 8e Linux LVM
Disk /dev/hdi: 2000.3 GB, 2000388448256 bytes
/dev/hdi1 32 4096031 2048000 83 Linux
/dev/hdi2 4096032 4608031 256000 82 Linux swap / Solaris
/dev/hdi3 4608032 3907008687 1951200328 5 Extended
/dev/hdi5 4608040 3906992303 1951192132 8e Linux LVM
Mar 6 17:25:58 RND4000 kernel: VERSION/ID : SB=(V:0.1.0) ID=<a2015108.00000000.00000000.00000000> CT:4f7b94f2
Mar 6 17:25:58 RND4000 kernel: RAID_INFO : DISKS(TOTAL:4 RAID:4 PARITY:1 ONL:4 WRK:4 FAILED:0 SPARE:0 BASE:0)
Mar 6 17:25:58 RND4000 kernel: SZ:3907008688 UT:00000000 STATE:0 LUNS:2 EXTCMD:1 LSZ:3907008686
Mar 6 17:25:58 RND4000 kernel: LOGICAL_DRIVE : 0: B:0000000032 E:0004096000 R:1 O:1 I:1:000000000 DM:f
Mar 6 17:25:58 RND4000 kernel: LOGICAL_DRIVE : 1: B:0004096032 E:3902912686 R:4 O:1 I:1:000000000 DM:f
Mar 6 17:25:58 RND4000 kernel: PHYSICAL_DRIVE: 0: DISK<N:0/1,hdc(22,0),ID:0,PT:1,SZ:3907008688,ST: B:online>
Mar 6 17:25:58 RND4000 kernel: PHYSICAL_DRIVE: 1: DISK<N:1/2,hde(33,0),ID:1,PT:1,SZ:3907008688,ST:P :online>
Mar 6 17:25:58 RND4000 kernel: PHYSICAL_DRIVE: 2: DISK<N:2/3,hdg(34,0),ID:2,PT:1,SZ:3907008688,ST: :online>
Mar 6 17:25:58 RND4000 kernel: PHYSICAL_DRIVE: 3: DISK<N:3/4,hdi(56,0),ID:3,PT:1,SZ:3907008688,ST: :online>
Mar 6 17:25:58 RND4000 kernel: CURRENT_DRIVE : DISK<N:0/1,XXX(22,0),ID:0,PT:1,SZ:3907008688,ST: B:online>
Mar 6 17:25:58 RND4000 kernel: Need to do drives searching.
Mar 6 17:25:58 RND4000 kernel: Find p d at 1, chn 1
Mar 6 17:25:58 RND4000 kernel: Total=4; raid=4; ready=0; work=4; failed=0
Mar 6 17:25:58 RND4000 kernel: Check degraded mode, start_pos=1
Mar 6 17:25:58 RND4000 kernel: No drive missing, X_RAID run in opt mode.
Mar 6 17:25:58 RND4000 kernel: Change X_RAID running mode from 0 to 1
Mar 6 17:25:58 RND4000 kernel: ::::Update backup SB.
Mar 6 17:25:58 RND4000 kernel: X_RAID: recovery thread got woken up ...
Mar 6 17:25:58 RND4000 kernel: New = 1, source drives = f, current/active=4/4
Mar 6 17:25:58 RND4000 kernel: :<6> hdc: hdc1 hdc2 hdc3 < hdc5 hdc6 >
Mar 6 17:25:58 RND4000 kernel: :<6> hde: unknown partition table
Mar 6 17:25:58 RND4000 kernel: :<6> hdg: hdg1 hdg2 hdg3 < hdg5 >
Mar 6 17:25:58 RND4000 kernel: :<6> hdi: hdi1 hdi2 hdi3 < hdi5 >
