trumpy81
Jun 26, 2012Aspirant
NV+ Transfer rates
GDay All, I have just installed a RND4000 V3 NV+ onto my network and I'm a little disappointed with the transfer speeds. At best I get an average of 7.2mb/s up and down which is dismal compared to ...
Jun 26, 2012Guru - Experienced User
Are you using cat 5e or cat 6 cable? Also, if you look at the numbers before/after a transfer are you seeing increases in the errors?
