trumpy81
Jun 26, 2012Aspirant
NV+ Transfer rates
GDay All, I have just installed a RND4000 V3 NV+ onto my network and I'm a little disappointed with the transfer speeds. At best I get an average of 7.2mb/s up and down which is dismal compared to ...
Jun 26, 2012Guru - Experienced User
ok, so there is no increase in the error stats during the 1 GB xfer.
Not sure if the NV+ was shipped with a 5e cable or not, though the grade is almost always printed on the cable, so you can check.
Do you have flow control enabled on the realtek? Also, did you test both read and write speeds?
