trumpy81
Jun 26, 2012Aspirant
NV+ Transfer rates
GDay All, I have just installed a RND4000 V3 NV+ onto my network and I'm a little disappointed with the transfer speeds. At best I get an average of 7.2mb/s up and down which is dismal compared to ...
BikeHelmet
Jun 30, 2012Aspirant
Turn jumbo frames off. Try turning journalling off too. Then reboot the NAS and test again. You should be able to get higher speeds than you're getting.
How are you measuring read/write speeds? An hour at even 2MB/sec is 7.2GB - far more than your data set, indicating your file copy speed isn't very accurate. Have you tried replacing it with something more accurate like TeraCopy? (Free for personal use.)
http://codesector.com/downloads/
