trumpy81
Jun 26, 2012Aspirant
NV+ Transfer rates
GDay All, I have just installed a RND4000 V3 NV+ onto my network and I'm a little disappointed with the transfer speeds. At best I get an average of 7.2mb/s up and down which is dismal compared to ...
trumpy81
Jul 01, 2012Aspirant
If you SSH in and run top, you can see the CPU usage bouncing all over the place as the NAS and your addons do things.
BikeHelmet, I'm not sure exactly what you mean by 'run top' ?
I completed the update to 4.1.9 and it did make a small improvement to the write speeds. I'm now getting an average of 15.5MB/s, but it fluctuates between almost 0 and 18.2MB/s when transferring files between 300MB and 2GB.
The fan speed seems to adjust much less frequently and to a slightly slower speed than before also. Overall, at this point in the game, I'd have to say that FW 4.1.9 is a winner! ... :lol:
I did manage to find an update for my NIC Drivers. Oddly enough though, the NIC on this motherboard is PCI and NOT PCIe. I have no idea why ASUS chose to use a PCI chipset instead of PCIe, but that's how it goes ... :lol:
The drivers made no difference though and they still don't include IPv6 for some reason. Since IPv6 has finally been rolled out I find it odd that this NIC doesn't seem to support it, or maybe it does but there are no options to change it? I'm sure the NIC's in my other machines do support IPv6 though.
