trumpy81
Jun 26, 2012Aspirant
NV+ Transfer rates
GDay All, I have just installed a RND4000 V3 NV+ onto my network and I'm a little disappointed with the transfer speeds. At best I get an average of 7.2mb/s up and down which is dismal compared to ...
BikeHelmet
Jul 01, 2012Aspirant
'top' is a linux command which gives you CPU/memory usage stats for all the processes currently running. Think of it as a text-based 'Task Manager'.
IPv6 should work fine over any NIC - but there won't be any acceleration or offloading, so your CPU has to do all the work. Over the PCI bus (rather than PCIe), and with extra CPU overhead... I can't see you ever getting full gigabit speeds for IPv6 stuff. Oh well, not a major loss.
