Ricardo_K
Feb 25, 2016Aspirant
NV+ v1 After firmware update shows Booting done!
After the new update the NV+ v1 rebooted and shows in LCD: booting..... done And nothings works anymore. I did a OS reinstall, no go. I did an USB Recovery, no go. Removed all drives and in...
Ricardo_K
Hi Stephen,
I did the last update, to RAIDiator 4.1.14 [1.00a043].
Its indeed JOBD in this one. No Raid config.
I have 3 NV+ and all 3 had problems, but this one is the big one.
Al my personal data, digital pictures are on that disk.
Ricardo_K
Hi Stephen,
TestDisk just finished with Search.
1st Partition: Files are present and I can copy them (OS, no need for that)
2nd Partition: Support for this filesystem hasn't been implemented.
So, I can't continue with recovery.
Richard
- StephenBFeb 25, 2016Guru - Experienced User
You could try R-Linux. Or possibly contact Netgear and ask about per-incident support.
