aks
Mar 16, 2016Virtuoso
NV+ v2 backup to USB drive (Seagate 5TB)
I am feeling a bit lost with getting USB drive ready for backups. In the past I just backed up to a RN Duo v1 (my old unit), but it does not have sufficient space anymore. I have a RN NV+ v2, and...
- Mar 16, 2016
Hi aks,
For ReadyNAS 5 or v2 units, it is recommended that you use FAT32 or NTFS file system. For USB backup and permission pointers, check the device software manual and turn to pages 83-85.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
Mar 16, 2016NETGEAR Employee Retired
Hi aks,
Hope this helps!
Kind regards,
BrianL
aks
Mar 17, 2016Virtuoso
Hi Brian,
Thanks for the tips. I'll use NTFS and give it a try.
I haven't experimented yet with USB backup yet, but NAS-to-NAS (my NV+ v2 to Duo v1) I could get the ownership permissions across. Actually I set up the Duo to pull because (from memory) the NV+ v2 does not have NFS support. I will try USB later and check whether permissions are maintained.
Thanks
- aksMar 17, 2016Virtuoso
So I formatted the drive as NTFS and tried a backup to USB from my NV+ v2, and all the files in the backup become owned by root. It does not seem possible to save permissions?
