aks
Mar 16, 2016Virtuoso
NV+ v2 backup to USB drive (Seagate 5TB)
I am feeling a bit lost with getting USB drive ready for backups. In the past I just backed up to a RN Duo v1 (my old unit), but it does not have sufficient space anymore. I have a RN NV+ v2, and...
- Mar 16, 2016
Hi aks,
For ReadyNAS 5 or v2 units, it is recommended that you use FAT32 or NTFS file system. For USB backup and permission pointers, check the device software manual and turn to pages 83-85.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
Mar 16, 2016NETGEAR Employee Retired
Hi aks,
Hope this helps!
Kind regards,
BrianL
CarlRossi
Mar 22, 2016Aspirant
Hi,
I also have a 5TB USB drive that I would like to use to backup my NAS but v1 not v2. I have 4 X 2TB in the NAS. So ...
I formatted the drive NTFS in a WIN 10 OS and it showed up as 'no file system' in Radiator when attached to the NAS and at only 2TB.
then I formatted ext3 within Radiator and it showed attached with FS but with only 2TB.
Then I tried formatting with Mac OSX disk utility to exfat full 5TB and attached also showed no FS and 2TB.
Question: Is there a way to get the whole drive usable? If not, sounds like I need two 2TB USB drives. ? !!!!
thanks
- aksMar 23, 2016Virtuoso
I have a Duo v1 too, and the disk limit is 2TB.
On that unit, the USB is very slow which for backups not so much of a problem really. The alternative approach is to connect it to your Mac or PC and back up the NAS via the network. You'll get the full space, but it means you'll have to leave the Mac/PC switched on during the backups. You can still use a backup job from the NV+ v1 to do this and I found the backup job setup on the v1 units to be more comprehensive than the v2 units.
I suggest starting a new thread if you have specific questions.
- CarlRossiMar 23, 2016Aspirant
Thank you. I have a server on my network that is always on so that solution works for me.
