gimbers
Mar 11, 2015Aspirant
NV+ v2 expansion limits
Hello All, I have been round and round the forum, but seem to be going round and round in circles! I can't search for "NV+" or "v2" as they are too common, but I want to make sure that I get an ans...
Mar 11, 2015Guru - Experienced User
Correct. The limits are actually TiB, but that doesn't change the result. 1 TiB is 1024*1024*1024*1024 bytes. 1 TB is 1000*1000*1000*1000 bytes.
gimbers wrote: 1. Am I affected by the "cannot expand more than 8TB" rule so that the max storage would be 9TB (4 x 3TB with 9TB storage and one 3TB drive redundancy?) I couldn't put 4 x 4TB drives in?
Also basically correct. Presently you have 3 TB (~2.72 TiB).
gimbers wrote: 2. Either way, I just pull out one 1TB drive (after backing up all my data first!), with the NV+ v2 on, remove it from it's caddy, wait 10 seconds, put a 3TB drive in the caddy and re-insert, waiting for the sync to complete and then do the same with the other drives. Re-boot NV+ v2 after all of this is completed and I have tripled my storage capacity?
When you insert the 2nd 3 TB drive you will end up with 5 TB (~4.55 TiB). Likely you will need to reboot after the second drive syncs to get the expansion (not waiting until disk 4 resyncs).
Then insert the 3rd drive (it will expand to 7 TB or ~6.36 TiB), and the fourth (ending up at 9 TB or ~8.19 TiB)
I don't have a v2, but the sync will likely take more than 12 hours, so inserting one a day is reasonable.
The benefit of the hot-insert method is that your data is accessible throughout the process. The factory reset with 4x3TB installed would be faster. But it would take the NAS offline for a day or so, and would require you to set up the NAS again and restore your data from backup. The reset also would re-set your growth limit, so you could expand to 16 TiB in the future.
