bmwcoding
Apr 06, 2015Aspirant
NV+ V2 not booting through after reset [24963130]
[case 24963130 just opened] Hi, I'm very new to ReadyNAS and got a used NV+ V2 purchased 04/2012 with 2 x WD30EZGX (slot 1 and slot 3, it was offline for some months) and I had to erase all data...
RX
Apr 06, 2015Luminary
It seems that your WD30EZRX drives are not compatible with the NV+ v2. You may check it here: http://kb.netgear.com/app/answers/detail/a_id/20641
Check if your NAS is whether an NV+v2 or NV+v1 on this link: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
Check if your NAS is detected on RAIDar without any drives inside it.
Check the WD30EZRX drives you have using the WD Data Lifeguard Diagnostics for Windows: http://support.wdc.com/product/download ... =612&sid=3 -- I suggest you to run an Extended test
