bmwcoding
Apr 06, 2015Aspirant
NV+ V2 not booting through after reset [24963130]
[case 24963130 just opened] Hi, I'm very new to ReadyNAS and got a used NV+ V2 purchased 04/2012 with 2 x WD30EZGX (slot 1 and slot 3, it was offline for some months) and I had to erase all data...
bmwcoding
StephenB wrote: What firmware is running in the NAS?
How did you erase the data?
May you please tell me how to check which fw is running?
I erased the disks with RAIDar after factory reset via setup button instead of RAID configuration.
