bmwcoding
Apr 06, 2015Aspirant
NV+ V2 not booting through after reset [24963130]
[case 24963130 just opened] Hi, I'm very new to ReadyNAS and got a used NV+ V2 purchased 04/2012 with 2 x WD30EZGX (slot 1 and slot 3, it was offline for some months) and I had to erase all data...
bmwcoding
Perhaps that helps for your further diagnosis:
Via bootmenu I access the technical support and telnet to the NAS and logged in. I see:
/dev # ls | grep sd
sda
sda1
sda2
sda3
sdb
sdb1
sdb2
sdb3
/dev # cat /proc/partitions
major minor #blocks name
31 0 1536 mtdblock0
31 1 128 mtdblock1
31 2 6144 mtdblock2
31 3 16384 mtdblock3
31 4 106496 mtdblock4
8 0 2930266584 sda
8 1 4194304 sda1
8 2 524288 sda2
8 3 2925545912 sda3
8 16 2930266584 sdb
8 17 4194304 sdb1
8 18 524288 sdb2
8 19 2925545912 sdb3
So the two disks are well recognized with 3 partitions.
And the /var/log/enclosure.log shows:
fan!!1!!status=ok::descr=1365RPM
disk!!1!!status=ok::descr=Channel 1: WDC WD30EZRX-00MMMB0, 2794 GB
disk!!2!!status=ok::descr=Channel 2: WDC WD30EZRX-00MMMB0, 2794 GB
disk!!3!!status=not_present
disk!!4!!status=not_present
model!!0!!mode=home::descr=ReadyNAS NV+ v2::arch=arm1::jbod=1
/dev # ls | grep sd
sda
sda1
sda2
sda3
sdb
sdb1
sdb2
sdb3
31 0 1536 mtdblock0
31 1 128 mtdblock1
31 2 6144 mtdblock2
8 0 2930266584 sda
8 1 4194304 sda1
8 2 524288 sda2
8 3 2925545912 sda3
8 16 2930266584 sdb
8 17 4194304 sdb1
8 18 524288 sdb2
