ainarssems
Dec 28, 2013Aspirant
NV+ v2 poor performance
I bought NV+ v2 to upgrade from D-Link DNS-320L mostly to get better performance and I am very disappointed with results. With D-Link I was getting 35MB/s read and 40Mb/s write speeds, with NV+ I was ...
Dec 31, 2013Guru - Experienced User
I agree the NV+ v2 should be faster - something is likely wrong. Though I don't own one, so I usually can't offer much specific troubleshooting advice on that model.
Did you try turning flow-control on in the PC NIC? Also, did you check the SMART stats?
If you purchased this new, you could contact Netgear support and see if you can get an RMA.
