baraloo02
Nov 24, 2012Aspirant
NV+ v2 Write Performane WD20EFRX 2TB WD REDs
Setup - Wired Ethernet, 1 Netgear Router, all Cat5e Cables. WNDR4500 Cat5e Eth 4 2TB WD REDS - Supported - WD20EFRX All NICs support GbE Write Speeds: 10MB/s External USB 3.0 write to i...
baraloo02
Looking like you are right,
I got my router model mixed up, wndr3400 netgear which is indeed 100mb -_- which means i need to get a switch or a new router fun times.
Appreciate the initiating the re-investigation on that part. I had looked at that before, but caught the wrong model number.
Let you know when i swap a switch in there, probably monday.
