cras
Jan 19, 2013Aspirant
NV+ v2 wrong capacity after expansion; 2TB instead of 3TB
Hello @all, I have an ReadyNAS NV+ v2 with RAIDiator 5.3.7 and a Flex-Raid-Configuration with JBOD. I use a 3TB hard drive and 2x2TB hard drives. I added another 3TB-HDD in Bay 4. After a few mi...
cras
Jan 23, 2013Aspirant
Thank you for your test.
Here are my configuration and the logs:
Bay1: WD30EFRX (3TB)
Bay2: WD20EARS (2TB)
Bay3: WD20EARS (2TB)
Bay4: WD30EFRX (3TB)
I can't change the position of the HDDs in Bay 1 -3, because I don't have so much backup space at the moment ;)
"mdstat":
and here is the partions.log
"mdstat":
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md5 : active raid0 sdd3[0]
1948794912 blocks super 1.2 16k chunks
md4 : active raid0 sdc3[0]
md3 : active raid0 sdb3[0]
md2 : active raid0 sda3[0]
2925544832 blocks super 1.2 64k chunks
md1 : active raid1 sda2[0] sdd2[4] sdc2[2] sdb2[1]
524276 blocks super 1.2 [4/4] [UUUU]
md0 : active raid1 sda1[0] sdd1[4] sdc1[2] sdb1[1]
4193268 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
***** Disk partition log from 2013/01/20 *****
***** Disk partition log for channel 1 [sda] *****
Disk /dev/sda: 5860533168 sectors, 2.7 TiB
Logical sector size: 512 bytes
Disk identifier (GUID): 66FC21AB-FB5C-4EF6-93F7-F033431A09F9
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 5860533134
Partitions will be aligned on 64-sector boundaries
Total free space is 4092 sectors (2.0 MiB)
Number Start (sector) End (sector) Size Code Name
1 64 8388671 4.0 GiB FD00
2 8388672 9437247 512.0 MiB FD00
3 9437248 5860529072 2.7 TiB FD00
# partition table of /dev/sda
unit: sectors
/dev/sda1 : start= 1, size=4294967295, Id=ee
/dev/sda2 : start= 0, size= 0, Id= 0
/dev/sda3 : start= 0, size= 0, Id= 0
/dev/sda4 : start= 0, size= 0, Id= 0
***** Disk partition log for channel 2 [sdb] *****
Disk /dev/sdb: 3907029168 sectors, 1.8 TiB
Disk identifier (GUID): DD6C3DA2-A9DE-4D10-A897-68D01EEB8C6D
First usable sector is 34, last usable sector is 3907029134
Total free space is 30 sectors (15.0 KiB)
3 9437248 3907029134 1.8 TiB FD00
# partition table of /dev/sdb
unit: sectors
/dev/sdb1 : start= 1, size=3907029167, Id=ee
/dev/sdb2 : start= 0, size= 0, Id= 0
/dev/sdb3 : start= 0, size= 0, Id= 0
/dev/sdb4 : start= 0, size= 0, Id= 0
***** Disk partition log for channel 3 [sdc] *****
Disk /dev/sdc: 3907029168 sectors, 1.8 TiB
Disk identifier (GUID): 5C6C8CBF-2185-4D84-9EDE-72E04C828870
# partition table of /dev/sdc
unit: sectors
/dev/sdc1 : start= 1, size=3907029167, Id=ee
/dev/sdc2 : start= 0, size= 0, Id= 0
/dev/sdc3 : start= 0, size= 0, Id= 0
/dev/sdc4 : start= 0, size= 0, Id= 0
