cras
Jan 19, 2013Aspirant
NV+ v2 wrong capacity after expansion; 2TB instead of 3TB
Hello @all, I have an ReadyNAS NV+ v2 with RAIDiator 5.3.7 and a Flex-Raid-Configuration with JBOD. I use a 3TB hard drive and 2x2TB hard drives. I added another 3TB-HDD in Bay 4. After a few mi...
cras
Jan 30, 2013Aspirant
As the first, thank you for your help. I have now found the solution.
My problem is a bug in the firmware. These always uses the smallest HDD as an reference for the capacity when a new disk is added in JBOD mode. This is regardless of drive bay. After I had backed up the data of the two 2TB HDDs and these were removed. The 3TB HDD is correct formatted with 3TB.
