svdhoorn
Nov 21, 2019Aspirant
NV+ won't boot. ERR: Bad Firmware
Hi there! I seem to be have the exact same problem as user '@zenandjuice' here. He stated his solution as follows: "mdgm, i want to thank you for your help. support was able to connect remot...
TinoJR
Jan 31, 2020Aspirant
Hi Marc,
i have the same issue, but i don't need to recover any data, i just want the nas to function again. I've tried factory reset, and os reinstall, and usb boot option install, but have same result . If i boot into tech support mode, i'm assuming it will allow me to SSH into the nas? If so, do you have any recommendations for next steps?
Thanks,
Tino
Feb 01, 2020Guru - Experienced User
You'd use telnet, not ssh. The username is root, the password is infr8ntdebug.
However I don't know if you can repair the bad firmware error that way or not. If the flash memory is failing in the NAS, you likely can't.
